Author Topic: What's available at Jaben  (Read 13411 times)
Offline Darkkopi
« on: Jul 27, 2008, 15:28:25 »
    • AKG
    • Alessandro
    • Audio-Technica
    • BeyerDynamic
    • C & C Amps
    • Corda HeadPhone Amps
    • CrossRoads Headphones
    • DarkVoice HeadPhone Amps
    • Eddie Current
    • ESI
    • Etymotic Research
    • FireStone Products
    • FreQs
    • Grace Design
    • Go-Vibe Portable Amps
    • Grado
    • Hall Crystal Flutes
    • HeadAmp
    • Hearing Components, Comply Tips
    • Heed HeadPhone Amps
    • Infrasonics
    • Koss
    • Lavry Engineering
    • LiveWires, Custom IEM
    • MiniBox Portable Amps
    • M-Power Amps
    • mSeed Amps
    • Original CD Players
    • Ray Samuels Audio Products
    • Rudistor
    • Sennheiser
    • Sensaphonics
    • Shure
    • Sleek Audio
    • Starkey
    • Storm Audio Portable Amps
    • SureFire
    • Travagans
    • Triad Audio; LISA amps
    • Ultimate Ears
    • Ultrasone
    • Visely Portable Amps
    • Westone In-Ear-Monitors
    • Yamamoto
    • Yuin
[/list]
« Last Edit: Aug 08, 2008, 03:37:46 by Darkkopi »
DA10 > GSX > HD800/LCD3
Offline Darkkopi
AKG
« Reply #1 on: Aug 02, 2008, 15:18:59 »
« Last Edit: Aug 03, 2008, 21:00:46 by Darkkopi »
Offline Darkkopi
Alessandro
« Reply #2 on: Aug 02, 2008, 15:19:21 »
Superior Design & Precision:
All Music Series headphones have a vented diaphragm design that incorporates a large air chamber. This design lowers the frequency resonance (distortion) of the diaphragm and extends bass response. A unique process to de-stress the diaphragm results in enhanced inner detail. The diaphragm is made of a low mass polymer, carefully formed to broaden resonant modes to reduce their amplitude. The diaphragm's total mass is calculated to provide a full 20 KHZ bandwidth while avoiding breakup at lower frequencies.
The Music Series One, Two and Pro headphones all feature voice-coils that are wound from ultra-high purity, long crystal (UHPLC) oxygen free copper. Ultra-high conductivity copper yields the clearest transmission and lowest coloration possible. This combined with high power neodymium magnets provide maximum efficiency giving a smoother, cleaner and more dynamic sound and a larger perceived sound stage.
Music Series One
Music Series Two
All metal work for the Music Series Two is machined from a special non-resonant, very hard alloy. A special processing method is used to increase the materials porosity. This complex treatment insures that the earphone chamber has no "ringing" which might obscure detail or add coloration. The Music Series Two model also utilize UHPLC in its connecting cable.
Music Series Pro
The wooden Music Series Pro model is hand-crafted at our labs from a specially selected species of mahogany. An intricate procedure of curling is done between production steps to achieve optimal sonic quality. The overall sound remains pure, warm harmonic color, full bodies vocals, excellent dynamics and an ultra smooth top end. The Music Series Pro model also utilize UHPLC in its connecting cable.
« Last Edit: Aug 08, 2008, 03:26:39 by Darkkopi »
Offline Darkkopi
Audio-Technica
« Reply #3 on: Aug 02, 2008, 15:26:05 »
under construction
« Last Edit: Aug 02, 2008, 15:42:27 by Darkkopi »
Offline Darkkopi
BeyerDynamic
« Reply #4 on: Aug 02, 2008, 15:34:46 »
DT 150
Wide frequency response 5 - 30,000 Hz
Highest fidelity
Extended bass response
High long-term wearing comfort
Modular construction for easy servicing
Detachable cable
DT 231 Pro
Lightweight, closed headphone
Single-sided, straight cable
Powerful bass reflex system
Supraaural
Soft, exchangeable ear pads
With stereo mini jack & 1/4" adapter
DT 770 Edition 2005
As any other model of the Premium series, the DT 770 is a perfect combination of design and function made in Germany. This headphone features a true sound definition with phenomenal bass response and the closed design ensures excellent ambient noise attenuation to enjoy music without any disturbances.
• Analytical, true sound reproduction
• Innovative "Bass reflex" system
• Excellent ambient noise attenuation
DT 880 Edition 2005
If anything of the legendary DT 880 could have been improved, it has been realised with this version. This top headphone combines the strengths of open and closed headphones. The complete sound spectrum is reproduced in detail from the deepest sub bass to the highest highs. This semi-open, dynamic headphone is also manufactured in Germany.
What specialists publications tell about DT 880...
“With a price label of € 269, the DT 880 is certainly an expensive pleasure. Having said that, I do emphasise the word “pleasure” because the sound is immaculate and the standard of finish is fantastic. Although it weighs 290 grams, it is so comfortable to wear that, combined with its half-open earpiece, you hardly notice the fact, even after extended listening periods. (...) A top-flight headset for sound gourmets who may intermingle audio books with Beethoven’s fourth symphony to give their ears a real treat.”
“a score of 6 out of 6”
(Hörbücher [audio books], 02/2007)
“A top-flight headset for sound gourmets” (Hörbücher [audio books], 02/2007)
“Truly excellent” , “The headsets sound gentle, peaceful and perfectly balanced”, “94 out of 100 points” (DIGITAL TESTED, 03/2007)
“The headset from beyerdynamic is ideally suited to act as a linear mastering headset.” (Videoaktiv Digital, 04/2007)
• Very linear sound
• Excellent sound location
• Ambient sound is attenuated, but can be still perceived (semi-open design)
DT 990 Edition 2005
The new sophisticated DT 990 is a headphone for enthusiasts and will satisfy you with a perfect sound and comfort. The use of high-quality material and the distinctive design underline the standard of a high end model. The headphone is still handcrafted in Germany warranting a high quality.
What specialists publications tell about DT 990...
“Voluminous and spatial sound and really comfortable to wear” (APAots, 27.8.2007)
• Analytical and high-resolution audio reproduction
• Strong bass and treble
• Lightest headphone of its class
A1
With the introduction of the A1, beyerdynamic enters a new area of audio reproduction. After intense fundamental research, beyerdynamic have succeeded in developing a brand new audiophile-quality headphone amplifier, providing precise audio performance even when used with our demanding 600 ohm premium line headphones. With its unique intelligent-circuit concept, the A1 is capable of reproducing an amazingly wide frequency range which stretches way above human perception.
As an example, the entire circuit is capable of handling frequencies of up to 96 kHz, which enables the transfer of uncompressed audio from either SA-CD or DVD Audio. A micro-processor-controlled relay allows noiseless switching between two different high quality audio signals and avoids unpleasant clicking when powering the A1 on or off.
Underneath the large front-panel-mounted aluminium volume control is a high grade ALPS-potentiometer for smooth volume adjustment. This is just part of the attention to detail that ranges from the outer unit construction to its quality integral components - use of a generously-dimensioned toroidal core transformer, plus a combination of carefully selected components allows even the highest-impedance headphones to be driven flawlessly over the entire frequency range.
The provision of a special impedance headphone output ensures that the control range of the volume potentiometer is also perfect for headphones with lower impedance.
The first of the two provided line-ins is hardwired to the A1 line out. The result allows the incoming signal to be loopedthrough even with the A1 in standby mode. So you only have to power up the A1 if you want to increase the enjoyment of your music using your headphones. Two blue LEDs in the front panel monitor the active signal input, with a further multicolour LED giving information about the A1’s operating status. The beyerdynamic A1 - The uncompromising “true companion” for your headphones and a pure masterpiece in audio achievement.
What specialists publications tell about A1...
“beyerdynamic’s tiny titan made child’s play of bridging the gap between the challenges of different converter concepts. (...) The wide bandwidth of this amplifier smoothed away any areas of hardness and, even though its core character is analytical and ultra-precise, all rounded off by a powerful basso profundo, altogether neutral mid-range sound characteristics and the feel of an open room. (...) Purest high-end experience for the head, without any ifs and buts.“ (Image Hifi, 06/2007)
“For low-key connoisseurs”
“Incidentally, the diminutive hiss and crackle levels on the A 1 are as good as it gets and the frequency pass drops by one decibel up to 100 kHz.
The A 1 was also entirely convincing in the listening test. On the classic DT 880 from beyerdynamic it played with great clarity and purity, with a tight bass and clear, clean trebles. At the same time, even when compared to other high-end headset amplifiers, it remains sober and matter-of-fact at all times, and does not allow itself to indulge in any spectacular forms of exaggeration. For example, it does not invest singing voices with greater volume levels than they have in natura. This does not indicate any absence of emotion, but instead delivers pure reality.“ (Stereo, 10/2007)
“With a price tag of almost € 1000, the A 1 is most certainly expensive, but the sound quality more than makes up for this fact.”
“In terms of sound quality, the A 1 headset amplifier sets new standards. What it has to offer by way of resolution, tone colour realism and dynamics is profoundly impressive, all to a standard not achieved by any other specialist headset amplifier.” (avmagazin.de, 6.7.2007)
“The amplifier operates almost entirely without background hiss. Even if you turn up the volume adjuster to maximum, no hiss is audible.”
“A very positive feature is that this amplifier develops its full sound right down at low volume levels, and those levels can be adjusted very precisely.”
“Voice reproduction is also very natural and never sounds too dry. Instead, it always seems very lively and authentic.”
“Summary: The small A1 really has what it takes.“
“Hiss or distortion, even at high volume levels, would only be audible if the unit was malfunctioning.“
(APAots, 27.8.2007)
“The A1 will serve us in future as a working tool for headset comparisons by virtue of its scope for universal application with automatic impedance adjustment and its good sound qualities.“ (HiFi & Records, 02/2007)
“An incredible win over the mediocre headset connections on CD players or AV receivers. beyerdynamic offers the kind of pre-amp which, in conjunction with the Manufaktur DT 990 headset, puts many speakers costing ten times as much firmly in the shade.“ (Maxim, 09/2007)
“Audio uses the new A 1 headset amplifier from beyerdynamic as its reference amp“ (Audio – statement from listening test, 12/2007)
• Big volume control with high-grade ALPS potentiometer
• 2 LEDs to indicate the active signal input
• Multicolour Power LED
• 1/4" headphone socket (6.35 mm)
• Two stereo inputs for 2 sound sources, 2 selector buttons
• Stereo output
• Stand-by button
and many more..
« Last Edit: Aug 03, 2008, 14:21:44 by Darkkopi »
Offline Darkkopi
C & C Amps
« Reply #5 on: Aug 02, 2008, 15:41:46 »
under construction
« Last Edit: Aug 02, 2008, 15:42:13 by Darkkopi »
Offline Darkkopi
Corda HeadPhone Amp
« Reply #6 on: Aug 02, 2008, 15:43:15 »
under construction
Offline Darkkopi
CrossRoads
« Reply #7 on: Aug 02, 2008, 15:44:52 »
Crossroads Mylarones [Svi,x3i,Lbi,xBi]
Crossroads PLD amp
Crossroads Edge amp
« Last Edit: Aug 02, 2008, 23:27:24 by Darkkopi »
Offline Darkkopi
« Reply #8 on: Aug 02, 2008, 15:45:57 »
« Last Edit: Aug 03, 2008, 21:03:59 by Darkkopi »
Offline Darkkopi
ESI
« Reply #9 on: Aug 02, 2008, 15:46:14 »
nEar04 is a high fidelity dual amplified bookshelf monitoring speaker system for desktop usage.
nEar04 is designed to overcome all the typical limitations of conventional small sized monitoring speakers providing a special 4" polypropylene curved woofer cone and a 1" natural silk dome tweeter.
nEar04 inherits professional monitor speaker quality from our famous and extremly successful nEar05 eXperience model.
Despite the small size, nEar04 still provide reference level sound quality and enough power for audio monitoring in a digital audio production environment.
As upgraded version of our popular nEar05 classic speakers, the nEar05 eXperience near field reference monitors have been developed especially for high level home studios and special project studios.
The nEar05 eXperience takes 5" near field monitoring speakers to a new level. They boast an ultra-flat low frequency response and the top quality Kevlar 5" driver delivers unparalleled punch in the low-mid frequency - a major improvement over the paper and polypropylene drivers used in most comparable products. ESI was the first vendor using kevlar for studio monitors in this price range as material inside the low frequency driver. Other vendors have since copied our idea, however there is much more to excellent sound: nEar05 eXperience still features ESI's cross over control technology that is perfectly optimized and upgraded to provide the perfect output level and frequency response 100% matching the installed drivers and cabinet design. Simply copying just one feature, does not work ... this is why we recommend to trust on the original design in case you are looking at any other similar looking product in the same price range.Of course nEar05 eXperience is magnetically shielded for desktop operation next to your other electronic equipment without interference.
nEar05 eXperience is already one of the most successful near field monitoring speaker in this price range that has ever been developed.
Optionally a nEar05 eXperience based monitoring system can be expanded with a subwoofer like our SW10K.
Intended as sucessor for nEar06, the nEar08 eXperience studio near field reference monitors have been developed to generate a near perfect sonic reproduction in any studio envrionment.
With an extended low frequency response and a top quality Kevlar 8" driver, the new nEar08 eXperience delivers unparalleled punch in the low-mid frequency - a major improvement over the paper and polypropylene drivers used in many comparable products. nEar08 eXperience, as the larger sibling of our popular nEar05 eXperience, also provide frequency response adjustment controls, allowing you to tune the sound, specific to the needs inside your studio environment. The monitors are featuring ESI's cross over control technology that is perfectly optimized and upgraded to provide perfect output level and frequency response properly matching the installed drivers and cabinet design. nEar08 eXperience is magnetically shielded for desktop operation next to your other electronic equipment without causing interference.
« Last Edit: Aug 08, 2008, 03:23:13 by Darkkopi »
Offline Darkkopi
Etymotic
« Reply #10 on: Aug 02, 2008, 15:47:11 »
  • er6
  • er6i
  • er4b
  • er4p
  • er4s
Offline Darkkopi
FireStone Products
« Reply #11 on: Aug 02, 2008, 15:47:41 »
under construction
« Last Edit: Aug 02, 2008, 15:48:16 by Darkkopi »
Offline Darkkopi
FreQs Custom IEM
« Reply #12 on: Aug 02, 2008, 15:50:12 »
under construction
Offline Darkkopi
« Reply #13 on: Aug 02, 2008, 15:51:27 »
  • Govibe Petite
  • Govibe Petite with DAC
  • Govibe DAC
  • Govibe Magnum with DAC
Offline Darkkopi
Grado
« Reply #14 on: Aug 02, 2008, 15:53:15 »
  • iGrado
  • SR 60
  • SR 80
  • SR 125
  • SR 225
  • SR 325i
  • RS 1
  • RS 2
  • GS 1000
« Last Edit: Aug 03, 2008, 20:59:43 by Darkkopi »
