Author Topic: [WTA] Recable cans...  (Read 53578 times)
Offline iQEM
  • Au-id owner
  • ex Team Planar (Ortho)
    • Audiophile Indonesia's Forum mail ?!
« on: May 13, 2008, 13:40:59 »
disini sapa yg bisa ya ? trus ada yg bisa ajarin teorinya utk DIY ngga ya ? kali aja suatu saat pengen/perlu, thx ! :D
« Last Edit: May 13, 2008, 15:56:37 by Ron »
History: Motorola A2DP HT-820, Koss KSC11, sennheiser (PMX60), AKG (K24p, K26p, K518dj, K501 [LP] with K701 pads, K400 [LP]), Ultrasone (DJ1, HFI580), Audio Technica (ATH-2), Sony (DR-11), AKG K12p, dbE HF10 mod, Fostex T20v2 mod, NAD RP-18 [basslight mod Kabeer], NAD RP-18 kapton modded with pads Koss MV1, Yamaha HP1 aniso mod, Fostex T10, Fostex T30 black/regular fork, with pads Beats Detox, Germania recabled, Fostex T30 silver fork, with pads beats Detox, ipod photo 4thGen 40gb, S.O.U.L SEv.1 (custom), Shuffle 1st GEN 1gb
Now: Vido with mic + KZ HD9 + KZ ATR + KZ ZSN pro + Yamaha YH3 modded + DIYcans 120ohm + JBL Ref 510 NC mod
Team Ortho
me love Headstage...
tested cans
My Feedback, to give me feedback, just click Here !
Team Cheap Bastard Head-Fi
mantan Team Rokok..not anymore..
Offline Ron
Re: [WTA] Recable cans...
« Reply #1 on: May 13, 2008, 13:48:40 »
Quote from: iQEM
Teorinya? Cuma lepas kabel lama dari drivernya, trus solder kabel yg baru.
Masalahnya... gimana cara ngebuka headphonenya? Masing2 merk/tipe kan beda2 cara ngebukanya.
Trus itu area yg sensitif, maksudnya ngga boleh sembarangan senggol sana senggol sini. Kalo kesenggol driver headphone, bisa robek. Kalo robek... suaranya pecah. Ehehe... :D
Experientia docet.
Offline equinox
« Reply #2 on: May 13, 2008, 14:44:33 »
Gimana kalau soal pemilihan kabel?
Kalau cari kabel yang bisa bikin karakter cans lebih bright ambil kabel apa ya? Mereknya?
AKG K501 + K701 pads - Etymotic Research ER6i + Shure Black Olives - Fischer Audio Eterna rev 2 - dbE HF30 - iPod Nano 1st Gen - Blackberry 9000
Offline Harlin
    • My Blog [IMG]http://i40.tinypic.com/2popnpc.jpg[/img]
« Reply #3 on: May 13, 2008, 17:03:06 »
Cari yg silver aja hehehe...
Setau gue cable yg bright itu Klotz... gue punya soalnya.
Sources: iPod Video 80gb modded, iPod Video 80gb unmodded
Interconnects: Van den hul (LOD & mini-to-mini), Silver 4-braid & 8-braid LOD, AudioNote mini-to-mini
Buffers: MoonVoice Buffer v2
Amplifiers: MVN1 premium, MVN2 v2 premium
Headphones: Woody Sennheiser HD600 (recabled with MV Prodigy X and Furutech plug), Fostex T20v1 Orthodynamic (recabled with MV Indigo and Cardas Rhodium plug)
Team MoonVoice
Offline iQEM
  • Au-id owner
« Reply #4 on: May 13, 2008, 17:47:25 »
nah, nemu juga gw...nih gw share...
[spoiler]
Headwize Grado Mods Page
Code: [Select]
http://headwize.com/projects/showfile.php?file=grado_prj.htm
Grado Starquad Recable (needs pics relinked) by Darwin022
Code: [Select]
http://www.head-fi.org/forums/showthread.php?t=110431&highlight=recable
Detachable Cables on a Metal Grado by hugz
Code: [Select]
http://www.head-fi.org/forums/f6/diy-guide-detachable-cables-metal-grado-142410/
My Grado sr-80 recable diary (pics) 56k by RnBfan
Code: [Select]
http://forum.teamxbox.com/showthread.php?t=343149
Recable your Grado/Alessandro (applies to sr-60,sr-80,ms-1,ms-2
Code: [Select]
http://www.monkeyfaq.com/grado_recable/index.html
1st DIY recabling job: K1000 by applebook
Code: [Select]
http://www.head-fi.org/forums/f6/1st-diy-recabling-job-k1000-207203/
AKG K701 Balanced Recable by cotd
Code: [Select]
http://www.head-fi.org/forums/f6/guide-balanced-akg-k701-recabling-225819/
AKG K601 Recable by RnB180
Code: [Select]
http://www.head-fi.org/forums/f6/so-i-recabled-akg-601s-pics-inside-160528/
AKG K501 Recable by kugino
Code: [Select]
http://www.head-fi.org/forums/f6/recabling-k501-pics-295031/
Modding & Tweaking the AKG K340 by aerius
Code: [Select]
http://www.head-fi.org/forums/f6/modding-tweaking-akg-k340-112264/
Akg K81DJ Ground signal wire by Vamps
Code: [Select]
http://www.head-fi.org/forums/f6/akg-k81dj-ground-signal-wire-248503
beyerdynamic DT 880 Recable Guide by Jam Master J
Code: [Select]
http://www.head-fi.org/forums/f6/beyerdynamic-dt880-re-cable-guide-progress-172825/
beyerdynamic DT 770 Recable by fordgtlover
Code: [Select]
http://www.head-fi.org/forums/f4/recabled-my-dt770-131800/
EquationAudio RP-21 and the Neutrik 1/8" mod by warrior05
Code: [Select]
http://www.head-fi.org/forums/f4/rp-21-neutrik-1-8-mod-247243/
Portapro re-solder? by dougmwpsu
Code: [Select]
http://www.head-fi.org/forums/f6/portapro-re-solder-200850/
A Mod That Improved My JBL 410 Reference (bisa juga utk AKG K412p/414p/dst) by 1Time
Code: [Select]
http://www.head-fi.org/forums/5081145-post15.html
oh, iya...sedikit tips utk yg mau pake kepang2 utk kabelnya (ala ALO)
Code: [Select]
http://www.stringpage.com/braid/medbraids/medbraids.html[/spoiler]
ntar kalo nemu lagi gw edit lagi utk tambahin disini... ;)
« Last Edit: Dec 15, 2008, 10:54:18 by iQEM »
Team Ortho
tested cans
Offline hendry
    • Analog Audio
« Reply #5 on: May 13, 2008, 17:55:38 »
grado/ alessandro kalau mau buka menyiksa sekali, musti disemprot pake hair dryer kurang lbh 10 mnt sambil di tarik2
@iqem yg buat AKG 501 donk :D
Offline equinox
« Reply #6 on: May 13, 2008, 20:26:52 »
Quote from: iQEM
Gak ada K518dj bro? ;)
Offline equinox
« Reply #7 on: May 13, 2008, 20:29:57 »
Pake Klotz untuk apa bro?
Offline Harlin
« Reply #8 on: May 13, 2008, 20:43:21 »
Ya kalo mau bright pake Klotz, tapi itu bukan kabel speaker, tapi Interconnect hehehe...
Team MoonVoice
Offline equinox
« Reply #9 on: May 13, 2008, 21:03:37 »
oh gituuu...
lagi nyari2 alternatif untuk recable soalnya, need to find the right cable hahaha
Offline d4rk*bring
  • Minami Maho....
« Reply #10 on: May 14, 2008, 03:52:39 »
Pake equinox? Tapi biasanya sih buat senn yah? :D. hahaha.....
My proposed logos for SOUL, Official Amps for Audiophile-id :D.
Wishlist : Ultrasone DJ1(newline), Ultrasone HFI580...
Source: Sony MP3, Acer Aspire 5920, PSP--> Yuin PK3
Team :Yuin
Offline iQEM
  • Au-id owner
« Reply #11 on: May 14, 2008, 08:00:45 »
ada bro, ntar gw tambahin deh... ;)
Team Ortho
tested cans
Offline equinox
« Reply #12 on: May 14, 2008, 09:56:29 »
Quote from: iQEM
Quote from: equinox
Semalam gue cari2 gak dapet :(
Offline rangga
« Reply #13 on: Dec 15, 2008, 14:39:07 »
bisa minta recabling bwt koss ksc75 g?
thx..
myfeedback
Sony F-806 + Vorzuge Vorzamp Pure + Shure SE-215 w/ Oyaide Cable
Quote
Ketua tim Stax sebenernya Beyer fanboy sementara member senior tim Ortho sebenernya ngebet ama dynamic. Apa kata dunia? :kabur:
Offline iQEM
  • Au-id owner
« Reply #14 on: Dec 15, 2008, 16:10:36 »
KSC75 kayanya udah ada tuh di SINI !  ;)
Team Ortho
tested cans
