Author Topic: [Guide] Buying Audio Equipment  (Read 24897 times)
Offline mbotie
  • Hunt hunt hunt....
Re: [Guide] Buying Audio Equipment
« Reply #30 on: Aug 29, 2009, 00:40:09 »
hoho ngomongin kota kita neh. idem ah sama pertanyaan diatas
Hidden Gem Hunter
Offline fellas
« Reply #31 on: Jan 25, 2010, 23:50:15 »
sangat membantu nih, emang beda deh kalo momod yg nikin..
mantab
Offline jembas
  • simple man
« Reply #32 on: Feb 21, 2010, 03:34:37 »
waduh...
persis brur..
memang itulah yg diperlukan..
Nafsu g tahan dah...
emg dasar manusia :)
Offline polisidarurat
« Reply #33 on: Feb 21, 2010, 09:14:27 »
penawar racun dari expert...hehe
sangat bermanfaat buat beginner and nubie...
"tu ka baa jo lai..." :D
Offline cowok
« Reply #34 on: Apr 24, 2010, 00:44:57 »
Guide yang mantaaap. Thanks.
Offline reno
« Reply #35 on: Jun 01, 2010, 10:46:22 »
nice guide harlin. thx
All Because of Grace
Isaiah 40:31
"You can't get what you desire if you're too busy complaining about what you already have that isn't enough for you."
Offline H9S
  • Senior Member
  • Learn To Enjoy The Sound~
    • Heavy Equipment Solutions
« Reply #36 on: Jun 29, 2010, 22:08:37 »
Bro,
saya sering masuk Mangga Dua (*rencana mau denger audio), cuman asal dah sampai sana kok rasanya minder yah?? hmm.... soalnya dana terbatas ^^
maklum masih awam banget hehehe.....
ada advise?
IEM & Cans:
- Goldring DR150
- ATH A700
- Shure SE 535 LE
DAP:
- Sony X1050 (IC)
- Ipod Classic 80Gb
Amp & DAC:
- Topping D2)
Speaker
- T&V Hoch
Offline wongbelagak
« Reply #37 on: Aug 13, 2010, 07:11:21 »
makasih bt infonya bang, bermanfaat bnget bt newbie kyk saya inih  8)
Offline frostbitez
« Reply #38 on: Aug 08, 2011, 17:41:42 »
post deh udah lama ga ngikutin ini....ada saran untuk headphones/iem harga 1jtan kebawah?
disaranin Audio Technica m50...atau versi murahnya superlux 662f
ada komen en masukan?
Offline cya147
« Reply #39 on: Aug 08, 2011, 18:40:43 »
Baca2 dulu yang banyak, banyak thread yang tanya mirip kyk bro.
Tau dulu karakter yang diinginkan baru tanya lagi, klo ga orang2 jg susah mau bantu apa.
Offline HusJr
« Reply #40 on: Sep 16, 2011, 12:11:45 »
ada rekomend tempat beli di mangdu ga bro :D
gw lg nyari sansa clip nih T_T
gak nemu2
Offline suloveu
  • I love my music...
« Reply #41 on: Sep 16, 2011, 12:19:54 »
Lha... Pusat racun jakarta alias kantongkresek kan di mangga dua... :D
Di mangga dua mall lt.5 Blok C/117.
Atau kalau clip+ kayanya ada di proxtech di mal ambassador.
« Last Edit: Sep 16, 2011, 12:21:50 by suloveu »
- Di sini cuma untuk mencari cara menikmati musik dengan lebih baik dan benar -
Offline HusJr
« Reply #42 on: Sep 16, 2011, 12:45:34 »
abis liat di web kantong kresek, disana out of stock :(
Offline baithani
« Reply #43 on: Sep 17, 2011, 22:36:35 »
maaf ni kalau salah soale newbie..ane rencana mau beli headphone tapi budget cuma 500 rb jadi headphone apa yang bagus untuk dana segitu??mohon pendapatnya untuk senior2 sekalian
Offline shingetter
« Reply #44 on: Jan 11, 2012, 23:35:00 »
thanks buat guidenya bro. menurut gw sih ya emang balik lagi percaya kuping sendiri ama mesti tahan iman biar ga kena racun akut. jangan kaya gw, rencana cuman pengen bali a-jays two di tokonya bro hanhan malah keracunan beli gr07 :)
