Author Topic: All About Orthodynamic  (Read 233106 times)
Offline rangga
« on: Aug 06, 2009, 00:24:22 »
[spoiler]
Quote
Isodynamic (aka orthodynamic) driver principle
Isodynamic drive headphones have drivers with flexible plastic film diaphragms into which a flat voice coil (spiral or serpentine in shape-- see photos below) is embedded or glued on for even distribution of the drive force. That is, the diaphragm is driven more or less equally over its entire surface at once, obviating the need to make the diaphragm rigid so that it can therefore be as lightweight and agile and nonresonant as possible. Isodynamic diaphragms are either lightly tensioned or corrugated to supply restoring force.
Magnetic assemblies (bar magnets or perforated disc magnets) on both sides of the diaphragm supply the magnetic field against which the voice coil's varying magnetic field reacts, which makes the diaphragm vibrate.
Isodynamic diaphragms are more massive than electrostatic diaphragms, but the equal-force drive principle allows them to move very quickly and in a coherent, uniform way, so provided there is sufficient mechanical damping, an isodynamic headphone gives excellent transient response and a sound quality not unlike that of an electrostatic.
taken from http://wiki.faust3d.com/wiki//index.php?title=Isodynamic_%28aka_orthodynamic%29[/spoiler]
Gw kenal ortho gara2 diracunin ma iQem..parah dah mimin yang satu ini..kerjaannnya ngeracunin mulu... :D
Tapi abis denger ortho gw jatuh cinta banget ma suaranya..rapih bgt gitu...
Begitu ganti dynamic kerasanya kasar dimana2..kaya ada layer yang nutupin gitu... :P
Cuma jeleknya, ngedrivenya susah...dampingnya juga gampang2 susah. Kalo pas dapet susunan damping yang bagus n sesuai selera kita, suaranya manteb. Tapi kalo g ketemu2 kadang bikin mangkel juga. Tapi disitu asyiknya. Kita bisa bikin cans sesuai maunya kita.  :)
Tapi setau gw g semua ortho bagus si..ada juga yang jelek, sama kaya dynamic. kalo dari wikiphonia ada semacam tingkatan ortho gitu,,
Ni ada member yang bikin pengelompokan ranking ortho berdasarkan pendapat dia. Emang subyektif bgt si, tapi paling ga bisa jadi masukan lah kalo kita besok mau nyari ortho.
[spoiler]
Quote
Wualta: 05-15-2009
My opinions are based on the mods we have as of this moment and ranked by the results of those mods that I have heard myself, with exceptions noted. Tomorrow someone will get a bright idea and cure a longstanding peeve. A miracle might even occur: Someday, someone might be able to get bass from a Bang & Olufsen U70 without EQ. So this ranking is fluid. Case in point: the recent discovery by the proprietor of this here Wiki that Fostex significantly improved the sound of the once-thought-worthless current production T50RP. So don't just read the top few entries and run off waving your mom's credit card at the nearest online auction.
Some mods are effective but getting them just right is a pain. Some headphones are just physically difficult to work on. These are noted but don't affect the ratings.
And it's worth repeating that with different mods come very different sounds from a single headphone. You can customize many of these 'phones to match your equipment, and of course different equipment will change the sound a headphone makes. It should be kept in mind that lesser phones, once modded, can have more treble and bass extension than even the vaunted T50v1, but won't have its openness and the ease of a certain big-diaphragm je ne sais quois. So hang loose, ortho brothers; none of this is chiseled in stone.
Top Tier:
Fostex T50 (original version, 1978-79, aka T50v1)-- Really stinkin' rare. Keep your eyes peeled but don't hold your breath. Sounds very much like the Stax SR-X Mk 3 but with bass. Not basshead bass, and not the best, tightest bass you ever heard (the little Pro 30 beats it) but clean, pleasing bass. One of the hallmarks of the sound of this phone is emotional, not acoustic: when you wear the T50 you get the feeling of being in a world where everything is wonderfully balanced, where nothing is too much or too little, like good Asian cuisine. The T50 does everything well, though it does nothing better than all others. The response is smooth, extended (but not too much) and flat. Damping is factory-tuned (but because there is damping, headstage is not Lambdalike as you might expect). It's reasonably efficient (for good dynamic range) but not so much that you'll hear residual amp noise.
However, with all the different levels of Hell you'll have to go through to get one, the psychic bottom line looks far better for one of the 2nd tier 'phones, which can be modded to give similar, sometimes superior, but not identical results. Did I say rare? Rare. Fostex never made another headphone like it, and neither did anyone else. Is it the Best Headphone Ever? No, not at all, just a very capable and enjoyable one for the reasons outlined, and a great preview (or tease) of the isodynamic future that never came but which may yet come. Don't step on a friend to obtain one-- it's not worth that.
The T50 (2 versions, 1978-79 and 1980-?) is not to be confused with the different-looking 2002 Fostex T50RP (which also has two versions. See below). The 1980 Fostex T50v2, which looks like the v1 but with a different headband and subtly different cosmetics, is related to the v1 but uses a visibly different diaphragm. Only 1 example is owned by an HF member, and I haven't heard it. Confusingly, Fostex called it simply a T50.
Also confusingly, Fostex OEM'd several versions of the T50v2 using drivers that looked like (but didn't sound like) the T50v1's for NAD, Maior, Lafayette, and possibly others, but using the headband and cosmetics of the T50v2. None of these "clones" can be ranked as high as the T50v1, usually because the treble is weak, but not always (the uber-rare Maior is an exception).
Even more confusingly, there's evidence that some of the clones and variants actually predate the North American market introduction of the T50, leading to the suspicion that what the NA market knows as the T50 was actually a special model designed specifically to emulate the sound of electrostatics of the day. The Stax SR-X Mk 3 was introduced about a year earlier. Coincidence?
Close to top but with reservations:
Yamaha YH-100-- This is a vented-closed 'phone, so it'll never sound exactly like a T50, but it can sound really freakin' good in a variety of ways. Has bass and treble extension beyond that of the T50. Tricky to get exactly precisely obsessively perfectly right, but one of the few old Orthos that needs make no apologies.
Yamaha YH-1000-- Yamaha's flagship TOTL SOTA Orthodynamic. Even more rare than the Fostex T50v1, but you'll hear a lot about it, so it's here. Yamaha put the big earcup attachment/adjustment block right behind a vented-back earcup (a no-no), but yes, the YH-1000 does have a semi-open back and Yamaha did use some mechanical damping (plus some acoustic absorption) in the 1000, the only time they ever did both on any Orthodynamic. A quick look at the service manual and it's obvious Yamaha was pulling out all the Ortho stops (semi-open back! aluminum cups! rare earth magnets! copper voice coil! damping!). Nevertheless, it's basically a first-generation Orthodynamic, with a nontensioned pleated diaphragm clamped in the center, just like the HP-1/2/3.
Few people own this phone and fewer have described its sound, but the ones who own it do like it a lot. Sonically, it's dark, obviously a relative of the YH-100, but like the YH-100 it has great potential. The one example I've heard has light damping added but is still dark, pretty much as the frequency response graph published by Yamaha shows-- a 3dB/octave downward tilt hinged at 1 kHz. This is usual for Orthodynamics, but the YH-1000 seems more linear (fewer bumps and detours in the tilted response curve) than its lesser brothers, which means the diaphragm is well-controlled and the response should flatten out nicely with relatively simple modifications. The linearity means that this headphone will sound pleasing even when its response hasn't been made flat.
Caveats: Two known examples have had corrosion problems on the copper voice coil, requiring painstaking repair involving disassembly of the driver and the use of a binocular microscope to re-paint the tiny copper traces. Something to keep in mind if one is contemplating spending big money for a YH-1000. Also, despite the metal earcups, the struts that attach the earcups to the headband are plastic, as in the HP-1/2/3 and YH-100. Don't drop this 'phone.
A rare landmark headphone in great demand.
Fostex T20RP (first version, aka T20v2-- another good all-rounder, not rare, usually reasonably priced, and easy to work on. Dull and blah in stock form, though not actively unlistenably bad. Like the YH-100, needs extra-dense damping materials, which may take some time to find. Not to be confused with the later and similar-looking T20RP mk II, which is good only if it has the new-style earpads.
Yamaha YHE-50S-- another very rare one but since it's based on the more common YHD-3 (which I haven't heard, but which should be very similar), and has unique features which can be copied by DIYers, I thought I'd include it. Think of a miniaturized YH-100 with an open(ish) back. That's saying a lot. There's also a mono version, the YHE-50A. Small enough and efficient enough to be used with portable gear. Rated over the TOTL YHD-1 and YHD-2 because it has earcups (backwave control) and earpads (ditto). Note that the YHD-3 lacks the earpads and uses fabric-covered foam slabs instead.
2nd tier:
Yamaha HP/YH-1-- A good place to start your career as an apprentice Orthodynamicist. The low bass of the YH-100 is missing, but everything else is there with the simplest of mods (the socalled Stage One-- a simple felt disc or two placed behind the driver). If you're not a basshead, get one while the online auction prices are still reasonable... sometimes. Not the easiest headphone to work on due to idiosyncratic mechanical design. NOTE: There's an upgraded HP-1 with "keeper" plates on its magnets, giving 2dB greater efficiency. Comes in a black (not silver) box, still labeled "HP-1". Look for the phrase anisotropic ferrite in the specs.
Yamaha HP/YH-2-- Used some cheaper materials than its big brother the HP/YH-1, leading to some problems with crumbling foam in some cases, but sonically very like the HP/YH-1. Just won't play as loud. Comes in a spiffy maroon color. Quality control is a bit looser on this pair of twins, so your YH-2 may not sound like your HP-2. A pain to work on, though as with the HP/YH-1, the results will wash away your tears.
Yamaha YHD-1 and YHD-2-- I badmouthed the YHD-2 for years, but mine must have been atypical-- a nice way of saying busted. Oh,the hazards of judging a headphone from a single sample! Auditioning another YHD-2 plus the evaluations of other YHD-2 owners over the years has shown that the YHD-2 is a slightly less efficient and bassy YHD-1, pretty much as we'd expect. Smooth but dull out of the box, but that's what we want for a good modification outcome. A work of art that's actually a good working headphone. Downgraded only because they lack pads (which can be tweaked to tweak the sound) and cups, which give you backwave control plus room for damping materials. Otherwise they'd be in the 1st tier with the YHD-50S. As compensation the open design offers some extra headstage.
Audio-Technica ATH-2 -- Not too common and slightly crippled by a thick, stingily-perforated baffle, it's one of the very few inexpensive isodynamics with an open back. Easy to work on. Driver virtually identical to the one in the Pro 30. To operate at its full potential, the baffle has to be partially cut away, so not an easy mod for perfectionists.
Realistic Pro 30-- Cheap to buy, easy to mod, can give astounding results for effort expended, good (I'm tempted to say killer) bass, compact on the head except for the "antlers". What's not to like? Well, maybe the slightly elevated (but flat) upper midrange and treble. Sentimental favorite, since it was my first wholly successful mod, ca. 1987. The 'phone that should've spread isodynamicry to the masses, and may yet.
Yama HP-3/YH-3-- A bit of a gamble, due to very loose quality control. Some HP/YH-3s are poor-man's YH-100s and some aren't. Not the most common of the Orthodynamics, but not rare (yet). The variant HP-50 series(50, 50A, 50S) were designed to be sold with Yamaha electronic organs. Some claim the HP-50 series uses a unique, superior driver-- all I can say is mine does sound more like my YH-2 more than my HP-3 or YH-3. HP-50 series 'phones all come with a white paperlike layer over the front of the driver-- intended function yet to be determined. Snap-together construction (no screws), which sometimes leaves backwave-leaking gaps. NOTE: The HP-50A is wired mono and must be recabled for stereo.
Fostex T40RP (first version, aka T40v1-- The lack of deep bass is a deficit but not a huge one and bass EQ works well. Very extended and smooth top end, like no other non-stat headphone I've heard. One of the easiest mods (a chunk of foam) gets you there. Same warning as above about confusing this with its Mk II version applies.
3rd tier:
Fostex T50v2 OEMs, aka "T50v2 clones" or "T50 clones" (1980--86?)-- (includes NAD RP18, Maior RPT-50 and Lafayette RP 50)-- For the 1980 model year, Fostex changed the T50's headband from pivoted twin leather-covered-steel bands to a single padded plastic piece, and this is the headband we see on the OEMs labeled Maior, NAD, and Lafayette. Frankly, and to give you a basis for comparison, I like the modded YH-100 far better than the Maior, which suffers because it has an elevated midrange / treble. The NAD, on the other hand, starts dropping after ~2 kHz and keeps dropping-- Bass City. Now, having said that, the clones are T50s in every other respect-- it just sounds like there's a little guy inside with a graphic equalizer who's hellbent on futzing with the sound. Sigh. UPDATE: as noted above, these have what look like T50v1 drivers inside a chassis that looks like the T50v2, but the genuine and exceedingly rare Fostex-branded T50v2 (which Fostex flabbergastingly insisted on labeling simply T50) has a similar driver with a unique diaphragm and which doesn't sound like any of the OEM clones, according to the one owner we know of. Confused yet?
Again, this not to be confused with the much later and very different T50RP, which, I remind you once more, is now being smiled upon by Fostex in the form of life-giving new earpads, making it, in today's online-auction market, 1) affordable 2) available 3)listenable (good, not great) in stock form. Which is so unexpected it's ridiculous. So: if it doesn't have the new earpads (see the T50RP section of this wiki for photos), don't buy it. Make sure your seller has the latest production, known in Japan as T50RPn.
Fostex T30-- Great potential, but will need a lot of work to get at all of it. Very similar to the T50 inside, but with a less powerful, slightly less open magnet structure and a sound that's tilted basswise very much like the NAD, above. Though the dark sound of the big diaphragm grabs your attention right away and you find yourself listening to it, you won't for long-- the T30 is shockingly uncomfortable to wear. Just about as rare as the T50. Some HFers have devised big circumaural pads for the T30 that make it comfortable.
Sansui SS-100-- Fostex-made, with a driver that's a cross between the one in the T50v1 and the T30 but slightly closer to the T50. Arguably the prettiest ortho/iso ever made. Sonically similar to the Maior RPT-50 (good, not great; weak bass; not easy to work on), ergonomically clumsy (the earcups don't pivot but float on a rubber subchassis) and therefore a disappointment. Rare again.
Fostex T20v1-- Fostex's most famous headphone, used in recording studios worldwide, but definitely not audiophile material without modding, and difficult to get sounding just right. Comfortable, not expensive, easy to work on, but not very efficient and has an upper midrange peak that's hard to tame because it's caused by the conical shape of the baffle.
4th tier:
Interesting 'phones but ones that respond very little to simple modification-- that's why they're here. Most use the 55mm driver made by Peerless Mikrofon Bau, PMB, now known as MB Quart. I keep hoping someone will find the killer mod for these. I've been waiting four years.
Peerless PMB 100-- Best of this group. Two versions: Early version used a unique, damped PMB 55mm driver with extra, chamfered holes in a felt-filled chassis, and only HF member JadeEast owns one. Later version, which used a standard PMB 55mm driver in a hollow box chassis with absolutely no acoustic treatment, sounds wonderfully flat, though dry, from about 100 to 150 Hz on up. Below 150 Hz there be hippogryffes but not much bass, which will be found to have fallen off the edge of the map and lost in the shag. Strange Jecklin-design headset that promises much but delivers only a little. Some violently disagree with this, but I don't hear the spatial enhancements promised by the Jecklin open-frame architecture. And to me, the sacrifice of that much bass isn't worth it.
Telefunken TH 700-- Made by PMB in Germany using PMB's big 55mm pinch-type driver. Not much bass or treble.. and it's factory damped! Maybe with a LOTTA work...
B&O U70-- I'm a big industrial design freak, but enough is enough. A work of art first and always, and only secondarily a working headphone. The U70's driver doesn't improve significantly in a more sympathetic chassis. Uses the visually-same PMB driver as the TH 700. Top octave sliced off. Not much bass. It's at least easy to work on since its aluminum-clad plastic body snaps together.
RFT HOK80-2-- Made in East Germany, the old DDR. This phone and the next both use what appears to be the same 44mm East-German-made driver, believe it or not. The HOK has not much bass (very reminiscent of the PMB 100) and is very inefficient but decent mids and top end. Horrible earpads with a lifetime of about 2 years max, but still serviceable even after the seams have split. A very brave attempt considering the political and economic conditions of its birth. Historically significant and shows rare sensitivity to the driver type. Easily convertible to open-back, as if this were a feature planned by the designers. Will accept incredible amount of bass boost and will deliver real bass if you have the amp and EQ for it. Snap-together construction using sometimes brittle materials let some bass backwave leakage occur. Difficult to work on and not for everybody, but hard to ignore. Bass can be improved with dense, low-profile DIY earpads as demonstrated by a dedicated HF member, DefectiveAudioComponent, also known as DAC.
Goodmans OHP-10-- Very nice PMB-made (West German) headset with the East German drivers inside. The sound? well.. with flatter earpads and some better baffle seals... As it is, it doesn't sound as flat as the gnarly little HOK80-2! I seem to have the only pair on HF, and that's just as well.
5th tier:
Technics EAH-830-- Very innovative technically but with weak magnets and an uncomfortable, unnecessarily heavy headset and disappointingly blah sound.
RFT HOK80(v1)-- The first version of the HOK80. Interesting, but NO bass and very inefficient. What's there is surprisingly good, but...
Wildcards: I've only heard one of these myself, but they're tantalizing enough to mention them here, and we have some pretty thorough descriptions and mods going on the Big Thread.
Wharfedale Isodynamic(the original 1972 model, aka ID-1)-- I've heard a slightly modified (rear of driver sealed to back of cup) example and except for a big high-Q resonance in the upper bass, it's amazingly good, especially when you consider it was the first isodynamic headphone on the world market and sold for £20 (!!). Very rare in the US, much more common in the UK. Only one HFer owns one in good nick. Not surprisingly, he loves it. A notch filter would be a necessary accessory to live with it long term, but with that the Isodynamic shoots very close to the top. Very inefficient-- works best from speaker amps. Is it a "good-but"? More like a "great-but".
Wharfedale ID-2 / Leak 3000-- one member of the Euro Wing of orthodom does own these twins (which don't sound alike), and he better get busy and put his impressions up here. The drivers look similar to the ones in the Fostex T30 and T50. Not surprising, since Fostex licensed the technology from Rank, who bought up Wharfedale, Leak, and Strathearn.
Amfiton TDS-15 and Echo TDS-16 (early version)-- These tantalizing Russian (Ukraine) 'phones are owned by a couple of Euro HFers. The TDS-15 is approximately a Russian Fostex T50, with bar magnets and a serpentine voice coil but with unique features seen nowhere else. The TDS-16 is more like a YH-1 inside (perforated disc magnets, spiral voice coil) but the driver has clamps like a PMB and a flat, non-pleated diaphragm, not like a PMB. See the Big Thread for the owners' impressions.
Grundig GDHS-223 and 224-- One is a Fostex OEM with a T20v1 driver inside, the other uses an odd driver that we've seen nowhere else but looks a bit like the one in the PMB 100 v1, but with no clamps. One owner of the 224, one owner of the 223. Impressions and ongoing mods on the Big Thread.
Dual DK-720-- Again, one Euro owner, mods ongoing, looks promising. Has some features of the HOK 80 (!) but uses a low-tuned 55mm PMB driver.
[/spoiler]
Orthodynamic cans kalo ga salah si rata2 keluaran taon 70-80an. Jadul bgt..makanya susah dicarinya. Eh CMIIW yak..gw masi nubi di bidang per "orho" an.
Yang lain, om iQem, om Ian, ato siapa aja yang punya ato pernah denger ortho cans, boleh dunk disharing disini. Biar temen2 yang lain bisa tau juga... ;)
Sory kalo ada salah info dsb, tolong koreksinya yak.. :D
« Last Edit: Dec 17, 2009, 23:09:41 by iQEM »
myfeedback
Sony F-806 + Vorzuge Vorzamp Pure + Shure SE-215 w/ Oyaide Cable
Quote
Ketua tim Stax sebenernya Beyer fanboy sementara member senior tim Ortho sebenernya ngebet ama dynamic. Apa kata dunia? :kabur:
Offline wahyuwahyu
  • Feel The Emotion of The Music
Re: All About Orthodynamic
« Reply #1 on: Aug 06, 2009, 01:14:01 »
barusan beli, tapi belom tau masih ada nyawanya atau g.. :D
past : ipod nano 2nd gen, iTouch 1st gen, shuffle 1st gen, mini 2nd gen, meizu m6sp, Carat UD1, iPod photo U2, YUIN PK2, PK3, AKG k412p modded,  MS1 w/ quarter modded hd414 pad, MVN P1, hippo shroom, Realistic PRO30, aiaiai Tracks, Gundala, hippo pearl
now : [ iPod touch 3rd gen / Sony discman D-E440 + SOUL mini v2.1 + ??? ], dBE hf10, samsung p3
wishlist : pensiun  >:D
Offline iQEM
  • Au-id owner
  • ex Team Planar (Ortho)
    • Audiophile Indonesia's Forum mail ?!
« Reply #2 on: Aug 06, 2009, 07:47:02 »
kewl, dipublish juga akhirnya soal Ortho... :D
gw rasa abis ini pada berebut nyoba Ortho semua neh... >:D
absen dulu deh disini...
Team Ortho/Isodynamic
  • iQEM
  • endro
  • ian_trooper
  • redsosis
  • Questa
  • theha
  • as1klh0
  • rangga
  • wahyuwahyu
  • martinz
  • sentul_kenyut
  • deygun
  • rap21
  • goldpocket
  • annoep
  • wildkatze
  • tingm
  • mbotie
  • a_tumiwa
  • i_djoel2000
  • cya147
  • iNsPiRaSiKuSaTu
  • arianugraha
  • gka
  • pitsel
  • Harlin
  • Calico
  • fanboydrockin
  • kha_cokmunity
  • Earfonia
  • senotodrugs
  • boodies
  • nimrodcode
  • JabLai cOY
  • larrabee
  • popo_99
  • naoan
  • audio junior
  • k3ct
  • NAYOSO
available vintage ortho branded cans on indonesia:
  • Yamaha HP1000
  • Yamaha YH1000
  • Wharfedale ID1
  • NAD RP-18
  • Sansui SS100
  • Fostex T50v0
  • Fostex T30 silver&black fork japan version
  • Fostex T10
  • Fostex T20v1
  • Fostex T20RP aka T20v2
  • Fostex T40v1
  • Victor HP D-50
  • Yamaha YHD2
  • Yamaha YHD3
  • Yamaha YHE50A
  • Yamaha YH100
  • Yamaha HP1
  • Yamaha YH1
  • Yamaha HP2
  • Yamaha YH2
  • Yamaha HP3
  • Yamaha YH3
  • Yamaha HP50A
  • Yamaha HP50S
  • ATH 1
  • ATH 2 & VectorScan VSH5
  • Sansui SS L-55
  • Realistic Pro30
  • Eagle H4300
  • Victor HP-D50
  • Amfiton TDS-7
  • Amfiton TDS-15
sementara baru itu dulu yg ke sensus ama gw ya, ada yg mo nambahin barangkali ?
Ortho rank sementara versi gw:
1. Hifiman HE6 silver dragon/Audeze LCD2
2. Hifiman HE-5 LE balanced
3. NAD RP-18/Fostex T50v0/Yamaha HP1000/Wharfedale ID1
4. Sansui SS100/Hifiman HE5/Victor HP D-50
5. Fostex T10/Yamaha YHD3/Yamaha YHD-2/Yamaha YHE-50A/Gundala/Fostex T50RP
6. Yamaha YH100/Fostex T20v2/Fostex T20RP MK-II
7. Yamaha HP1/YH1/Fostex T40v1/Fostex T20v1
8. Yamaha YH-2/Fostex T50RP with v2 pads
9. Realistic Pro30
10. Yamaha HP3/Yamaha YH3/Yamaha HP50A/HP50S on custom housing
11. Eagle H4300
12. ATH1
13. Sansui SS L-55
14. ATH-2/VectorScan VSH5
note:
no.3 s/d 8 udah mod (kecuali ID1), rank2 dibawah itu cuma Pro30 sama T50RP yg stock form, laennya dah mod...
HE6, HE5 LE & HE5 udah recable... :)
« Last Edit: May 07, 2017, 17:00:21 by iQEM »
History: Motorola A2DP HT-820, Koss KSC11, sennheiser (PMX60), AKG (K24p, K26p, K518dj, K501 [LP] with K701 pads, K400 [LP]), Ultrasone (DJ1, HFI580), Audio Technica (ATH-2), Sony (DR-11), AKG K12p, dbE HF10 mod, Fostex T20v2 mod, NAD RP-18 [basslight mod Kabeer], NAD RP-18 kapton modded with pads Koss MV1, Yamaha HP1 aniso mod, Fostex T10, Fostex T30 black/regular fork, with pads Beats Detox, Germania recabled, Fostex T30 silver fork, with pads beats Detox, ipod photo 4thGen 40gb, S.O.U.L SEv.1 (custom), Shuffle 1st GEN 1gb
Now: Vido with mic + KZ HD9 + KZ ATR + KZ ZSN pro + Yamaha YH3 modded + DIYcans 120ohm + JBL Ref 510 NC mod
Team Ortho
me love Headstage...
tested cans
My Feedback, to give me feedback, just click Here !
Team Cheap Bastard Head-Fi
mantan Team Rokok..not anymore..
Offline heartless
  • FC
« Reply #3 on: Aug 06, 2009, 11:37:42 »
ooo...........suara yang dihasilkan ortho lebih bersih gitu ya bro?
My Past RIG™
Offline iQEM
  • Au-id owner
« Reply #4 on: Aug 06, 2009, 14:23:38 »
mungkin bukan "bersih" kali istilah yg cocok... :D
headstage lebih bagus diplanar (Ortho termasuk planar),  separation & positioning imaging tiap sonic tiap freq tampil sangat jelas dan tetap balance/netral...
detil & SQ bisa diadu sama hi-end dynamic cans yg rangenya diatas 5jt sekalipun, sedikit kelebihan Ortho dari elektrostatic/electret adalah, masih menggunakan jack audio biasa, jadi bisa pake amp konektor audio biasa, yg penting sinergi dan dari segi power mencukupi...
FYI Ortho/isodynamic lebih berat didrivenya dari dynamic cans, walopun keduanya memiliki impedance yg sama...jadi rasanya setingan hi-voltage hi-current yg cocok utk drive Ortho... :)
oh iya, utk yg bingung maksud dari headstage itu apa bisa dibaca secara mendalam di link berikut:
Code: [Select]
http://www.head-fi.org/forums/f13/stax-sr-007-omega-ii-review-after-4-years-ownership-40331/
« Last Edit: Aug 06, 2009, 14:26:23 by iQEM »
Team Ortho
tested cans
Offline rangga
« Reply #5 on: Aug 06, 2009, 15:02:32 »
Awas, kalo uda denger ortho biasanya ogah denger dynamic lagi..wkwkwkwkwk...
myfeedback
Quote
Offline heartless
  • FC
« Reply #6 on: Aug 06, 2009, 15:05:18 »
Code: [Select]
nice....ic ic.. :P
jadi kepengen....................... :D
My Past RIG™
Offline endro
  • Administrator
  • Audiophilia Nervosa
  • Hearing is believing
« Reply #7 on: Aug 07, 2009, 02:12:00 »
klo yg baca ini orang yg jual "dynamic" driver..bisa mencak2 mereka :P
*salah satu kekurangan ortho...bentuknya ga bagus jd jarang yg ngelirik..AMIEN kwkwkwkwk...
Hear with your ears then listen to your heart after that watch your wallet
SOUL AMP - OFFICIAL Audiophile-iD AMP
Offline iQEM
  • Au-id owner
« Reply #8 on: Aug 07, 2009, 04:30:03 »
rada kurang setuju gw, Dro... :D
bentuknya Ortho cans banyak yg bagus2 koq...kekurangan Ortho kalo menurut gw adalah jumlah jenis/brand terbatas (karena cuma muncul thn 70-90), jadi langka/susah dicari, jumlah unit pun terbatas... :-\ setelah Ortho hilang dari market, cuma Fostex yg masih rilis Ortho sampe skrg...
untung skrg ada 2 produsen (salahsatunya bener2 produsen baru) yg ngrilis Ortho ke pasaran lagi, yaitu Audeze & HeadDirect...pengen tau kaya gimana ? coba tengok di SINI :D
« Last Edit: Aug 07, 2009, 05:01:35 by iQEM »
Team Ortho
tested cans
Offline diboy
« Reply #9 on: Aug 07, 2009, 08:06:45 »
yeahhh.. must say..
bentuknya keren kok :D :D :D
Sansui... :D :D :D
Suaranya... :metal: ^^
Quote of The Day
From SB
Wah Ivan kok yang diperhatiin bokongnya sih bukan jins-nya :kabur:
Wah bro quarter ini kayak baru kenal Ivan aja :kabur:
lgs tepat pada sasaran :D :D :D :D
Anggota PBOT (Pengagum Berat Om Tumi)
Pendiri ITFC (Ian Troopers Fans Club)
Offline wahyuwahyu
« Reply #10 on: Aug 07, 2009, 09:56:27 »
kira2 kenapa banyak yg menghentikan produksi orthonya yah?
padahal kan kualitasnya d atas dynamic..
Offline Dayak
  • Sponsor AnalogHead
« Reply #11 on: Aug 07, 2009, 11:25:00 »
Wah, kalau orang berhenti bikin Ortho, itu persis kayak cerita piringan hitam.
Sekarang produk yang baru2, jauh lebih praktis makenya.
Kalau soal vokal, dengar dari piringan hitam, pakai perangkat tabung kelas satu, udah susah di cari tandingannya. Cuman makenya berabe, pakai PH, mesti di bersihin pakai yang khusus anti statik, kalau enggak ada bunyi pretek2 gitu.
Ortho cobain punya Bro Ian, suaranya emang bagus banget, tapi cuman bisa di drive sama Beta 22, pakai yang lainnya, suaranya bukan cuman enggak nyanyi, malah enggak bunyi atau cuman bisik2 doang.
Sekarang kalau kita balik ke soal praktis, gue ngerasa kehilangan loch sama CDP portable, yang baru sekarang udah bukan yang top of the line dari produk produsen audio terkenal.
Yang kelas top of the linenya udah pada enggak keluar lagi.
Team suka yang Portable :alis:
Offline wahyuwahyu
« Reply #12 on: Aug 07, 2009, 12:01:30 »
gitu ya,bro?
tapi misalnya aja ortho 120ohm beratnya hampir sama dengan dynamic 300ohm dalam hal ngangkat suara.
tapi kenapa yg dynamic 300ohm smpe sekarang masih bejibun dan ortho udah mandeg?
secara sama2 repot tuh..
Offline ian_trooper
  • Administrator
« Reply #13 on: Aug 07, 2009, 12:52:36 »
300ohm dynamic itu colok direct ipod masih sedikit nyanyi. kl ortho 120 or 150 ohm cm bisik2 :D
Ortho -- Anti IEM :D
Offline Dayak
« Reply #14 on: Aug 07, 2009, 16:20:48 »
Tapi emang kalau udah dengar suara Ortho, kita ngerasa pantas untuk bersusah payah.
Suaranya tuch vokalnya seenak K340, tapi separasi sama Bass dan Treblenya udah enggak kalah sama K701.
Cuman K340 di drive sama SR71A masih nyanyi, kalau Ortho cuman bisik2 doang.
