Author Topic: HEADFONIA STORE PROMO AKG AKG K142 HD Studio High Definition Semi Open Headphone  (Read 2734 times)
Offline Headfonia
  • Sponsor Headfonia
  • Pedagang
Rp2,400,000 Rp1,680,000
ONLINE SHOP http://www.headfoniastore.com/product/akg-k-142-hd-studio-high-definition-semi-open-headphone/
AKG K 142 HD Studio High Definition Semi Open Headphone
Comfortable and Durable
The ultimate comfort in personal listening starts with the AKG K 142 high-definition over-ear headphones. Their luxurious, self-adjusting headband conforms to your head, while their gimbal suspension allows the headphones to sit against your ears without pinching. And, of course, the headphones use replaceable velvet-soft ear pads, making them the perfect choice for everyday use and long listening sessions. They’re rugged enough for professional environments and comfortable enough for hours of continuous use. The AKG K 142 HD headphones will connect to virtually any portable audio device, including an older iPhone.
Self-adjusting headband keeps headphones
in place comfortably
Take a Step Up from the Ordinary
For today’s high-definition audio sources, only the best headphones will do. The K 142 HDs are a huge step up from other over-ear headphones, delivering the best in high-output sound and frequency response from virtually any portable device, including the iPhone. They feature a semi-open design with high-end drivers that deliver superior frequency response, with low frequencies reproduced all the way down to 16 Hz and high frequencies reproduced with dazzling clarity out past 24 kHz. They’re also designed for high output with minimum distortion, making them the ultimate upgrade for audiophiles who listen in mobile environments.
High Quality Materials Create High-Definition Sound
Extra-large speakers with Varimotion diaphragms provide higher sensitivity and a wider dynamic range. For the finest possible transmission of their wide frequency response, the K 142 HDs use a single-sided, 99%-oxygen-free cable. The hard gold-plated jack plug and contacts resist corrosion and enhance sound clarity.
Reliable Compatibility
You can use the K 142 HDs with your home stereo, portable DVD, CD and MP3 players and many other audio/video players. With their slim, tapered connector, the K142 HDs are compatible with all versions of the iPhone including first generation mode They’re an ideal upgrade to any portable device.
Specs
Audio Specifications
Frequency Response    18Hz – 24kHz
Maximum Input Power    200 mW
Input Impedance    55 ohms
Sensitivity    101 dB SPL/V
General Specifications
Earpads    Replaceable ultra-soft velvet
Headband    Self-adjusting
Cable    3.00 m
Connector    3.5mm hard gold-plated jack plug and contacts
Weight    225 g
Colour    Espresso Brown
Include Accessories    6.3mm adapter
What’s in the Box
One pair of AKG K 142 HD over-ear headphones with a 1/4-inch adapter and a 3-meter-long cable
Yudie
Headfonia Store
Mal Ambassador
Lantai 2, Blok B No.1
Jl. Prof. Dr. Satrio
0812-8602-3140
Headfonia Store - Toko Headphone, Earphone Terlengkap
AKG, ALO AUDIO, ASTELL&KERN, AUDEZE, AUDIO TECNICA, BOTTLEHEAD, CANARE, CAPDASE, CENTRANCE, CHORD, COMPLY, COWON, CYPHERLABS, DBE, DENON, EDIFIER, ETYMOTIC, FIIO, FITEAR, FOCAL, FOSTEX, FUJIPATU, GRADO, HARMAN KARDON, HEIR AUDIO, IBASSO, JAYBIRD, JBL, JDS LABS, JVC, KOJO TECHNOLOGY, NUFORCE, 1964 EARS, KOSS, LEXTRON, LOGITECH ULTIMATE EARS, MARSHALL, MRSPEAKERS, NATIVE UNION, NEUTRIK, OYAIDE, PELICAN, PHILIPS, PHRODI, PLANTRONICS, RADIUS, RAPOO, RAYS SAMUELS AUDIO, SANDISK, SANWA, SENNHEISER, SHURE, SONY, TOPPING, TOSHIBA, V-MODA, VOJO+, VSONIC, WESTONE, XIAOMI, YAMAHA, YUIN, ZERO AUDIO, ETYMOTIC, STAX, HIFIMAN, VIOELECTRIC, FURUTECH
~ Don't Believe The Hype ~
