Author Topic: (2nd Hand) Burson HA-160D - Discontinued (SOLD)  (Read 1487 times)
Offline AnalogHead
  • Sponsor AnalogHead
    • www.analoghead.com
« on: Jan 29, 2014, 16:30:05 »
Burson HA160D
Specifications :
- DAC 24bit/ 96kHz via USB (USB is compatible with both Mac and PC)
- Digital Inputs : 1 Coaxial RCA and 1 USB
- Analog Inputs : 3 sets (Gold-plated)
- 1 Preamp Output : with 10dB gain
- Headphone Outputs : 1 Low Gain, 1 High Gain
- Powered by 5 sets of custom built Low Noise Power Supplies to eliminate noise pollution
- 2 Custom-built Transformers : 1 is for the HD Audio DAC while the other 1 is for the Class-A Amplification. It ensures that both of the
  DAC and the Amp are working independently and at optimum level
- 6mm Resonance Free Aluminum (RFA), the enclosure was constructed as a mechanical damping factor (it reduces any microphonic
  effects that may degrade the sonic performance of the 160D) moreover it allows the Class-A Amp to run cooler and remain optimized
  at all times
Belinya langsung di Melbourne, barang masih mulus .. harga bagus ;)
(Kalau berminat, silahkan via PM ya)
Thanks
« Last Edit: Feb 24, 2014, 13:19:55 by AnalogHead »
Analog Head (www.analoghead.com)
The Friendly Headphone Store
STC Senayan, Lantai G no.17 (samping Vape Bar) - Jakarta 10270
https://www.facebook.com/AnalogHeadStore
https://instagram.com/analoghead_id/
Distributor & dealer: FitEar, Narmoo, InEar (StageDiver Series), NuPrime, Astell&Kern, Woo Audio, Vorzuge, Audeze, Nu Force, MrSpeakers, Matrix, T-Peos
Phone / SMS = 085-100-717-395 (Store Hours Only)
HP / SMS / Whatsapp = 0878-6116-8495 (at Anytime)
Line = analoghead
PIN BB = 53B1F716
