Author Topic: HEADFONIA NEW ARRIVAL ~ NuForce Mobile Music Pump  (Read 1334 times)
Offline Headfonia
  • Sponsor Headfonia
  • Pedagang
« on: Aug 05, 2013, 22:42:02 »
NuForce Mobile Music Pump @ IDR 700.000
The NuForce Mobile Music Pump (MMP) is a portable headphone amplifier designed to make your music truly come alive… wherever you go.
The fact is that the majority of hand-held audio playback devices simply aren't capable of adequately powering many of today's quality headphones. This is because headphones present a definite challenge to amplifier designers. There are two basic types: the Over-Ear (OE) in general use in the recording industry, and the smaller In-Ear (IE), a.k.a. "ear-bud" type commonly used with portable devices such as MP3 players.
Given the range of available OE and IE headphones, in attempting to accommodate them all, your mobile device’s headphone output is optimized for none. Typically, OE types exhibit sensitivities of about 100dB/mW, whereas IE devices can be 10dB higher or more, e.g., 110dB/mW. Assuming a 10dB difference, the lower sensitivity OE headphones require ten times more power to achieve the same volume as the IE type. If you’re using OE headphones, you’ll really appreciate the NuForce MMP power capability. Your headphones will sound distinctly clearer and more natural.
Just connect the MMP to the headphone output of your MP3 player, Smartphone, iDevice, etc. and finally start experiencing the higher level of performance your headphones were always capable of.
Features:
Input – (1) 3.5mm analog
Output – (2) 3.5mm analog
Adjustable Gain Button – 3X or 5X Gain (default setting = 3X)
Micro USB port for charging
Specifications
Audio Input:1 x 3.5 mm analog 1 x micro USB for power charging
Headphone Output:2 x 3.5 mm analog
Gain:3X or 5X, selectable by user
THD+N:0.09% @ 1 mW 0.45% @ 32 mW
S/N Ratio:>100 dB, 20 – 20 kHz A-Weighted
Frequency Response:20 – 20 kHz +/- 1.5 dB
Max Output:94 mW @ 32 ohm, 1.74 V, 10% THD+N 49.2 mW @ 100 ohm, 2.2 V, 10% THD+N
Battery Life:>8 hours
Battery Capacity:200 mAh
Charging time:70 mins
Dimensions:58.2 * 47.7 * 10 mm
Weight:22 g
Headfonia Store - Toko Headphone, Earphone Terlengkap
http://www.headfoniastore.com
AKG, ALO AUDIO, ASTELL&KERN, AUDEZE, AUDIO TECNICA, BOTTLEHEAD, CANARE, CAPDASE, CENTRANCE, CHORD, COMPLY, COWON, CYPHERLABS, DBE, DENON, EDIFIER, ETYMOTIC, FIIO, FITEAR, FOCAL, FOSTEX, FUJIPATU, GRADO, HARMAN KARDON, HEIR AUDIO, IBASSO, JAYBIRD, JBL, JDS LABS, JVC, KOJO TECHNOLOGY, NUFORCE, 1964 EARS, KOSS, LEXTRON, LOGITECH ULTIMATE EARS, MARSHALL, MRSPEAKERS, NATIVE UNION, NEUTRIK, OYAIDE, PELICAN, PHILIPS, PHRODI, PLANTRONICS, RADIUS, RAPOO, RAYS SAMUELS AUDIO, SANDISK, SANWA, SENNHEISER, SHURE, SONY, TOPPING, TOSHIBA, V-MODA, VOJO+, VSONIC, WESTONE, XIAOMI, YAMAHA, YUIN, ZERO AUDIO, ETYMOTIC, STAX, HIFIMAN, VIOELECTRIC, FURUTECH
~ Don't Believe The Hype ~
