Author Topic: Matrix X-Sabre "Desktop DAC" (Ready Stock)  (Read 1676 times)
Offline AnalogHead
  • Sponsor AnalogHead
    • www.analoghead.com
« on: Jul 16, 2013, 20:29:19 »
Hai Au-Id
Desktop DAC dari Matrix Audio ready di Analog Head :)
+ Rp 11,600,000
Features :
01. All New Design
     .. make it easy to playback the DXD and the DSD signals via the USB interface
02. Convenient Operation
03. Various Interfaces
     .. with the COAXIAL, USB, AES / EBU input mode
04. Native Support DSD DXD
     The PCM signal support up to 32 Bit/384kHz sample rate ..
05. CNC Unibody
     .. the separate compartments on each internal circuit unit, so it has a strong anti-jamming capability
06. Simple But Not Simple
     The design of the diamond cutting style .. it can minimizes the vibration ..
07. ESS Sabre
     .. the results are exceptionally wide dynamic range, ultra low distortion, accurate sound stage and jitter-free music clarity
08. X-Core
     .. it's the most advanced USB Audio Class 2.0 digital audio solution now .. support for Windows and Mac OS X
09. Direct Stream Digital
     .. sample rate which is 64 times or 128 times of CD format(44.1 kHz) sample rate
(Foto-foto & keterangan lengkapnya disini http://www.matrix-digi.com/en/products/49/index.html )
Impresi dari temen-temen Au-Id http://www.audiophile-id.com/index.php/topic,18106.0.html
« Last Edit: Jul 22, 2013, 11:45:19 by AnalogHead »
Analog Head (www.analoghead.com)
The Friendly Headphone Store
STC Senayan, Lantai G no.17 (samping Vape Bar) - Jakarta 10270
https://www.facebook.com/AnalogHeadStore
https://instagram.com/analoghead_id/
Distributor & dealer: FitEar, Narmoo, InEar (StageDiver Series), NuPrime, Astell&Kern, Woo Audio, Vorzuge, Audeze, Nu Force, MrSpeakers, Matrix, T-Peos
Phone / SMS = 085-100-717-395 (Store Hours Only)
HP / SMS / Whatsapp = 0878-6116-8495 (at Anytime)
Line = analoghead
PIN BB = 53B1F716
